Hi all,
I have 1988 520i e34 manual, and current rear diff ratio is 4.45 (as shown on the tag).
I am considering to change to lower ratio. Anyone has done this, and which ratio have changed to? Any side effect on engine?
Can i do bolts-on swap a diff from 1989 525i Auto? I think it's either 4.1 or 3.63?
But, there are too many rear diff from 525i 24V version, which is different to my 520i 12V version. It's a 3.91 LSD. If i want to use this, it seems i have to change the whole rear subframe? Is this worth to do? Do i need to change prop shaft too?
BTW, after changing this, i am considering to swapped engine with bigger CCs.
