Results 1 to 10 of 13
Thread: rear diff option for 1988 520i e34
    Default rear diff option for 1988 520i e34
    Hi all,
    I have 1988 520i e34 manual, and current rear diff ratio is 4.45 (as shown on the tag).
    I am considering to change to lower ratio. Anyone has done this, and which ratio have changed to? Any side effect on engine?
    Can i do bolts-on swap a diff from 1989 525i Auto? I think it's either 4.1 or 3.63?
    But, there are too many rear diff from 525i 24V version, which is different to my 520i 12V version. It's a 3.91 LSD. If i want to use this, it seems i have to change the whole rear subframe? Is this worth to do? Do i need to change prop shaft too?
    BTW, after changing this, i am considering to swapped engine with bigger CCs.
    it all depends on what kind of subframe and diff that car uses, i saw a picture of a early e34 520 once and it looked a lot like a e28s rear suspension, and if it is that opens up a few doors, like e30s and e28s which interchange between one another by swapping the rear cover and popping out and swapping the drive flanges (easyly knocked out with a block of wood) the e30/e28 diffs mount to the subframe with 4 bolts on the top of the diff plus one on the rear cover and have a 4 bolt flange for the driveshaft. i can't say for sure as all e34s imported to the us had the later suspension
    WInfred,
    Thanks for your reply. I went again the to junkyard. So happen to found one that close enough with 3.65 (this is good).
    Yes, it has 4 bolts on top, 1 on rear cover. But the rear cover is mounted to diff body with 8 bolts. I believe e30 has 6 bolts?
    The previous i had, the bolts are on the right side and one on top plus 2 diff mounting bolts at the rear cover.
    I'll give it a try and see if it will fit my e34.
    rahman
    theres large and small case e30 diffs, the 4 cylinder cars have a small case here and the 6s have the big case and can also have a posi traction unit in them, the e28 uses the big case here
    Quote Originally Posted by nsbone_1988_520i
    WInfred,
    rahman
    Austin, TX
    did you swap a manual tranny into your car? is that why you have 4.45's and a 5-spd?
    Quote Originally Posted by bimmerd00d
    Yes, a 4.45 and 5 spd. It's a standard config for 520i 12V here in Malaysia. THe 3.91 from later M50 engine would be too much work for conversion.
    I just gotten a right diff (i hope)with 3.64 ratio. Now, i am hoping the 3.64 can be fitted bolts on. And, what pros/cons will i get from the new ratio.
    Is yours a M20B25 engine? What's the diff ratio? Is there any diff part no to identify the diff?
    rahman
    Austin, TX
    I wonder if your 5th gear is a 1:1 like the one on my 1993 525i US spec with a 3.23LSD. If it is an overdrive 5th gear, you might run into a problem with the engine not being powerful enough to move the car with a lower ratio.
    OK, i believe you have an M5x B25 engine, which rear differential would be different to earlier ones.
    My gear is std gearbox with OD. and i realize, it will kill the ability to move the car. A M20B25 conversion is also on the way...
    Austin, TX
    ahh I see. There's a chart of which diffs came in which E34's on Bruno's site. www.bmwe34.net
    Default gonna have problems in OD for sure!
  1. Rear Diff. LSD Locked up
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 12-17-2008, 08:10 PM
  2. Rubbing noise from rear of 520i
    By GarethHart in forum 5 Series BMW
    Last Post: 06-02-2008, 01:15 PM
  3. e34 520i 1988 brake servo/check valve...
    By nsbone_1988_520i in forum 5 Series BMW
    Last Post: 06-25-2006, 07:27 PM
  4. rear diff on '95 540i 6 spd
    By YaoNYC in forum 5 Series BMW
    Last Post: 01-17-2006, 01:41 PM
