Results 1 to 10 of 16
Thread: strut tower brace?
    Default strut tower brace?
    is there a difference between the Racing Dynamics strut tower brace for the e34 535 and 540?
    Central NJ - USA
    good ques....i want the 535i one for my car =]
    same mounting points but different engines that they need to clear, one may fit both cars and the other may only fit the one car
    Quote Originally Posted by MaloventEvil
    its more likely that the 540 one will fit the 535 but not the other way around?
    possible
    Apr 2004
    Reston Va
    Default I live here in Alexandria and near Racing Dynamics
    My mechanic - A RD dealer tried to install the 540 Strut brace on my car as well as his 530iT. It causes a bow in the hood.
    The lead fabricator / engineer from Racing Dynamics came over to look at it - as they did not believe it - and was appalled that they missed the mark with their Brace that badly.
    They took my mechanics car over to their *LABS* (shop) and are fabricating new ones that actually fit the 8 with out the optional Hood Bow.
    I will report next thursday how this endeavor went when I pick up my car.
    I was in getting new Brake System; Suspension; Transmission; Major rear diff service; Valve cover Oil Seals and rear PCV Valve done along with new shocks and sways tires and wheels. When I said - what the heck lets throw that on too! Thats how we discovered it didnt fit.
    Stay tuned. - Jt
    Johntee540
    1994 540/6 Black - Tan - 199k
    well ****. i just traded jimmyz2 my sideskirts for a RD strut tower brace.
    Apr 2004
    Reston Va
    I wanted to update you. I got my "Modified" 540 Strut Tower Brace from RD today. It is lower than the one I originally had. And they are modifying the rest to be lower from here on out. However - the one I had gotten was the result of being cut too long and then being welded. When fit the bar bowed up causing it to hit the hood.
    The fix is to change the jig so that they use less bar and run them closer to the Engine. My Bar was a one off Quality control issue. They were however concerned and pulled several off the shelf to check on my car.
    The factory there is quite an interesting place. And it is really interesting to see how they fabricate this stuff. The owner has his Vintage 67 Porsche 937 Turbo Race car there in the shop. Only worth $347k. I was impressed with my little field trip my mechanic took me on today.
    So Malevolent Evil. You are more than likely way okay with your trade. Just wanted to update you. Sorry for the firedrill! - JT
    Johntee540
    sorry, forgot to post a followup to this thred. the bars are exactly the same, but for the 540, it also comes with a relocation bracket for what i think is the brake fluid reservoir.
    it was probably the hood pad, some have a thick pad some have a real thin pad
    Quote Originally Posted by Johntee540
  1. strut tower brace
    By arizona coyote in forum 5 Series BMW
    Last Post: 07-29-2008, 09:18 PM
  2. New E34 Touring mod - Rear Strut Tower Brace
    By Mr Project in forum 5 Series BMW
    Last Post: 10-09-2007, 09:01 AM
  3. strut tower brace(s)
    By bahnstormer in forum 5 Series BMW
    Last Post: 01-15-2005, 04:46 AM
