OK... had this problem for a while but until very recently didn't kow it was a problem......
My temp gauge has never normally read 12 o'clock since I got the car, normally it only goes up 1/4 of the way.
I have had the stat that the car came with, I have drilled this to help bleeding, I have put in a new (non genuine) stat which I drilled to help with bleeding, and with all of these, the stat only goes up 1/4 way during normal driving.
Today I had the car idling for a while (I actually also had the electrics disconnected from the heater valve because I was trying to work out if it was related to this because I also have a problem that I get no heat from the middle blowers, but heat from the windshield and floor blowers,) and the temp gauge went up to 1/2 way, but as soon as I started driving again, it went back down to 1/4 way.
I know I could try putting some cardboard infront of the radiator (!) and I'm now thinking about changing the stat again.... I could get one from the stealer for £23 or one from Halfords (like the one I bought the other day) for £11.20...... if that will definetley solve my problem, then I'll happily change the stat again to the stealer part, but if it's just an iffy/maybe then it's probably not worth it as I've already just changed it.
