Originally Posted by
Derek A.
Can you feel hot air being pumped by the fan when the car is running ? How old is the radiator on the car ? After you shut the car off how long does the cooling system hold pressure ? If the top hose collapses quickly I would guess that you have a leak somewhere. How does the engine oil look ? Does the car make steam a lot out the exhuast ?
Can you feel hot air being pumped by the fan when the car is running ? Which fan? Heater fan inside - yes. Main radiator fan - yes, but it doesn't appear to increase when hot (that's why I replaced the fan clutch to begin with, plus it spun a few turns, didn't come to an "abrupt" stop, when the engine is turned off hot) Aux radiator fan runs with A/C on. Temp still wanted to creep over 1/2 even with aux fan on.
How old is the radiator on the car? 2 months
After you shut the car off how long does the cooling system hold pressure ? Not sure, but it does seem to be pressurized when I remove the overflow tank cap, or open the bleed screw.
How does the engine oil look ? Good and clean
If the top hose collapses quickly I would guess that you have a leak somewhere. (Hard as a rock)
Does the car make steam a lot out the exhuast? It always has - no more than usual.
1990 535i 5-sp., except for 16" M-Contours, cd deck, and clear corners, completely stock. 226k and running strong
