Results 1 to 10 of 10
Thread: engine number
    Nov 2004
    Default engine number
    the engine num of my car has 256K as the first four characters...
    what type of engine is this and where can i find info on this? thanks!
    Default what car/year?
    Quote Originally Posted by pong
    Default That tells you that its a 2.5 liter six as explained here
    characters...
    what type of engine is this and where can i find info on this? thanks![/QUOTE]
    Nov 2004
    its a 90 525i
    i dunno whether or not the engine is an m50 version or the m20... from what i have read... it was in 1990 when the engine was changed frm the m20 to the m50. this is the reason why im bogged... do u guys know sites that show bmw engines? this way i may be able to identify the engine type
    tnx
    Elm Grove Farm, NC
    easy way to tell the difference between M20 and M50 is by looking at the valve cover (the top of the engine- where the oil fill cap is). The M20 has a long Aluminum valve cover- the M50 has a wide black plastic cover over the actual valve cover, almost all you see in the engine bay is black plastic because the intake manifold is black plastic too!
    HTH,
    Bret.
    Default Or do you have a distributor cap and spark plug wires? the m20 does and the m50
    doesn't
    its a 90 525i
    tnx
    Nov 2004
    ok... its an m20... where do i get info on this?
    Elm Grove Farm, NC
    what info do you want??? We'll be glad to help you, but you've gotta TRY to help us....
    Bret.
    Minnesota
    You could buy a Bentley repair manual for the E34 model. There's lots of information in there...
    Nov 2004
    i was planning to change the timing belts... i purchased this 2nd hand... i dont think d guy changed d belts of this car... is there a site where there are pdf files with pictures showing how to change the parts...
    thanks!
  1. Where is my engine number?
    Last Post: 07-27-2009, 05:14 AM
  2. where to find the engine number - info
    By shogun in forum 3 Series BMW
    Last Post: 02-02-2009, 05:51 PM
  3. engine-number
    By allerston in forum 5 Series BMW
    Last Post: 07-31-2008, 07:35 AM
  4. where to find your engine number
    Last Post: 07-23-2008, 07:37 AM
  5. engine number
    By ken in forum 5 Series BMW
    Last Post: 09-27-2004, 09:02 AM
