Five days ago my drivers side (L/H) wiper quit working in a hard rain on highway late at night... what better time? The splines inside the arm had stripped out. I was unable to find one from a wrecker and the local stealer didn't have one. I decided to attempt a repair. I had read in some other message board archives that new arms did not have splines in them, they were smooth and the wiper shaft sticking up cut new ones. It looked to me that if the inside of the arm was made smooth again and the gap on the end of the wiper arm was opened up, it may work.
Here's what it looked like when I pulled the arm off. Notice there is almost no gap on the end of the arm. It appears as if the wiper arm was not seated as far down on the shaft as it should have been. I'll never know how long it was like that. I guess the wipers on high speed the other night was all it could take. That last 15 miles sure did suck!
Here's what it looked like after spending a lot of time with a set of jewelers files. I smoothed out the the splines in the hole and opened up the end gap so the bolt could close things up tight and let it cut new splines. I've got about three hours of use so far and it appears that all is well. Hopefully this will help out someone else in a tight spot that has the same style wiper arm.
