It should, at least it does on my 93 525ia. There's a small bulb under there that may be burnt out.... or dicsonnected.... -, ROb.
Hi guys,
should the Auto Shifter selector trim with numbers on light up?
the switch next to it does.
on mine the numbers are painted white.
can i fit one from a higher spec model that lights up???
is there any models that have this E32 even?
Thanks in advance, Matt.
Haynes - "Fitting is Reversal of Removal"
i think he was thinking the panel around the shifter, not the dash... or i might be wrong assuming that no e34 has light up numbers since all of the 10 or so i've been in didnt... and i've been in all of them from 89 to 94Originally Posted by RobPatt
yes the panel around the shifter.
did E32`s have it? could poss upgrade?
Matt.
so many poster neglect to post what year their e34 is...and it makes it difficult to answer some questions because some features are year specific. The early e34/e32 did not have lights on or next to the PRND321/PRND432 (only the instrument cluster display)...later model e34/e32 do have a lighted dot next to the alpha/numeric characters. My 95 525iT has the lighted dots to the right of the PRND321 (see 1st pic below) they're kinda hard to see in the pic...but my 91 735iL did not light up and had no dots (see 2nd pic below)
My 91 735iL w/non-lit PRND321...
Q
95 525iT / 97 740iL
Thanks, Matt.
does anyone know how hard it is to install in a model with non-lit ones ? part numbers ?
should be easy to install just take the power for the bulb off the switch next to it.
Matt
switch ? which one ? i dont have the A<>M selector... I'm old school. If that's the one you are talking about.Originally Posted by A1BMW535iSport
yeah the switch is on mine so i`m ordering the new selector trim today from bmw collect 2moro then i`ll just link the bulb up to the power for the light on the switch next to it
Matt.
