Results 1 to 3 of 3
Thread: A/C-Heater system
    Bel Air, Maryland
    Default A/C-Heater system
    I'm having trouble with my system. I tried to turn on the a/c to clear the fog on the inside of the widshield and the little green switch lights won't come on for either the a/c ( snowflake symbol) or the recirculator ( circular arrows).
    I checked the fuses and they're O.K.
    I've been noticing an oder coming from the vents but it doesn't smell like anitfreeze. I attempted to replace the microfilter to solve that problem and discovered that my car doesn't have one.While I was poking around ,I noticed that there was a build-up of a greenish, stickey substance in the plastic cover for the evaporator. Does anyone know what this might be? It doesn't seem to be antifreeze.
    Thanks for your help1
    Will
    Nov 2004
    Your a/c system may be low on refrigerant that's probably why the compressor is not working, most automotive refrigerants have a green dye so that leaks are easy to find, i'm guessing that's the green build up on the evap cover, hook up a refrigeration gauge to check if you have any refrigerant in there.
    Bel Air, Maryland
    Thanks, I thought there might be a sort of safety device to protect the compressor.
  1. Replies: 10
    Last Post: 01-04-2009, 05:42 PM
  2. Replies: 4
    Last Post: 06-01-2006, 04:23 AM
  3. Replies: 3
    Last Post: 04-12-2005, 01:51 PM
  4. Heater system question...
    By grr in forum 5 Series BMW
    Last Post: 09-30-2004, 08:55 AM
  5. Dammit, heater valve didn't fix my heater...
    By Dan in NZ in forum 5 Series BMW
    Last Post: 07-01-2004, 07:01 PM
