Results 1 to 7 of 7
Thread: 85-95km/hr shimmy
    Mauritius
    Default 85-95km/hr shimmy
    Hi guys
    I had a very light shimmy at around 85-95km/hr and I did a wheel balancing this evening.Unfortunately, the results are worse. Now the whole car is shaking like hell at that speed.
    Unfortunately we dont have this special hunter machine for balancin the tires in my country.
    Fronyt suspension status- Thrust arm bushing 6000km(lemforder), center tie rod-3months old(TRW with BMW logo on it), Swing support-three months old.
    What are my options?
    Kentish
    540iA
    Jul 2004
    Default feel your pain
    Quote Originally Posted by kentish
    Hi guys
    Kentish
    540iA
    Changed to my bottle cap winters and lo and behold dreaded shimmy surfaced I re balanced wheels to no avail so I tried rotation and still a shimmy. I have replaced thrust arms with 750 bushings in past,and rest of front end looks fine and other wheels and tires were fine so when I rotated front to back one side at a time found the shimmmy was minimized Man this is a pain in the a__.So I ended up with tires the way had them on last winter and shimmy was again worse...so I ended up taking the R front wheel off+ sanding mating surfaces and turning wheel 1/5 of a turn seemed to fit on easier guess what ? shimmy cured. So I thought how many of us are putting new parts on unnecessarily because of this or a mechanic that does not understand how fussy these cars are? Try all the simple things 1st my mechanic friend thought I was nuts but changed his tune when problem was cured so try, try ,try and you might luck out. Kuly 95 540
    Manila, Philippines
    Default Same here, it's likely the mags or tires
    Kuly's right, did the whole change jig, even new brake rotors, new tires, wheel balancing, slight shimmy persisted between 60-70 mph. Brought it to wheel repair specialist, who did something to the rims (he said even my spare was off). Still a very slight shimmy, brought it back, he did it again, and now vibration (if any) very slight. Good luck!
    Vancouver, Canada
    Hey.. can you please elaborate your solution? I have this exact problem and after an alignment, wheel balance, and new left front control arm i cant' seem to get rid of it. oddly, it seems to surface once in a while.. sometimes not.. sometimes between 70-80kph, sometimes 85 kph.. etc..
    help!
    -inc
    '91 e31 850
    '90 e34 535
    '02 CBR F4i stunt/track bike
    '07 gsxr 750 stunt bike
    Mauritius
    check your rear whell balance
    Vancouver, Canada
    wheels are perfect.. the shop even showed me on the balancer.. plus the guys are my friends and always do amazing work.. so i'm still looking for the cause
    -inc
    '91 e31 850
    '90 e34 535
    tires are probably out of round. you can have a perfectly balanced set, even with the hunter road balance machine unless the tech is absolutley anal about it. balance issues are 40-70mph, tire issues are 75 and up mph. and thats even with perfect hubs, no rust, etc etc.
  1. Shimmy fix?
    By elbasha in forum 5 Series BMW
    Last Post: 07-06-2008, 08:34 PM
  2. 50-60 shimmy
    By aurora6408 in forum 5 Series BMW
    Last Post: 09-06-2006, 07:51 PM
  3. shimmy shimmy shake
    Last Post: 06-30-2006, 09:32 AM
  4. shimmy no mo
    Last Post: 04-27-2006, 02:12 PM
  5. 40-60 MPH shimmy
    By Jazzman in forum Suspension & Steering
    Last Post: 04-17-2004, 04:15 PM
