Question for steering gurus....need some help
Symptoms:
Wanders at highway speed. Large dead spot at center. Hard to drive in a narrow lane, because as soon as you get off the dead spot it is very sensitive. With the car on jackstands, I can grab both sides of the wheel and move it, which moves the steering wheel, but it seems too loose.
What I've replaced:
shocks and struts inclucing mounts
upper and lower control arms
center and outer tie rods
idler arm
Additional info:
I think a front wheel bearing is going out, could this be a contributing factor?
I've already tightened the steering column nut under the dash.
I've also messed around with the adjustment on the steering box, but it didn't seem to take away the dead spot, just changed steering stiffness.
Could I possibly need a new steering box, and if so, how much $$$?
Also the link fron the box to the center rod has not been replaced, but I doubt that's the problem.??
After replacing everything, I was hoping it would drive like a new car, but I guess it needs something more.
Thanks for your help.
Mike S.
1992 535iM black/black
1997 540iM white/gray
Retired: 89 535iA, 85 318i
<<Support your local autobahn, stay out of the left lane!>>
