Today i took out the intake manifold of my 525i,94...all went well except the for the part of disconnecting the hoses,they all as the same age of the car...
It was interesting,since its the first time i do such job on my car,and along came some findings i hope anyone could comment for better results
1- The intake manifold was soaked with oil,is it worth cleaning as possible of the oil deposits,and what type of cleaner can be used?
2- I noticed that on Cylinders 3 & 6 that there exists very black oily spots, while the rest are shiny alloy,does this mean anything,and what cleaner can i apply there to restore the alloy look?
The intake valves looked excellent,nothing unusual and they are very clean ,no carbon deposits.
While there,and since the car has a low Idle issue,i took out the ICV it was dirty,and i checked the Ohm, the readings as follows:
Pins 1+2= 11 Ohms
Pins 2+3= 12 Ohms
Pins 1+3= 22 Ohms
Per Bently,the readings are almost half the required spec, should this mean that the ICV is faulty? or is it better to have a new one tested and compared to my ICV readings...
Thnx...
