Hi all. This is Francisco and i want to make my 525i 1989 look or be lower . Can any one tell me a good set of suspention or sprint for my car(chip).. Thanks to all..
I like my Sachs kit because it's a good compromise of firmness, lowering, and comfort. There are, of course, other spring/shock combinations that people like. Since you're new to E34's you should spend some time on Bruno's website:
http://www.bmwe34.net/
Originally Posted by Patrick
Im running Eibach springs and Belstein sport shocks, firm but not jarring and it lowers the front conciderably compared to the stockers.
Originally Posted by 632 Regal
Same setup here... the tire brand makes a huge difference in ride.
One thing to remember on the Sachs kit is that you have two height settings to pick from on the rear.
I used the higher setting, which is close to stock (there is still a gap between the tire and the lip). This might address the alignment issue mentioned earlier (not 100% sure if it does).
Rod
Originally Posted by talltorontoguy
I agree on the Sachs kit. It really is great.
I went a little further and used 3mm spring pads on the front of mine to drop it almost an extra 1/4". The 3mm pads are from either the M5 or from a 540, can't remember which, but they fit right in there.
Got it all from BMA
Good luck,
Rod
Thanks Rod!
