Results 1 to 5 of 5
Thread: My speedometer is crazy
    Fogtown
    Default My speedometer is crazy
    Yestarday when pulling away from a light in heavy traffic, twice the speedometer just shoots up to 40-80 mph. Then it goes back to normal once I pick up some speed (only occurs when I am starting from dead stop). It doesn't happen each time, occured only twice yestarday.
    Default lokks like the speed sensor is the problem
    Check the wires first, if you cannot see anything wrong, remove the speed sensor and check that one.
    Sometimes just cleaning helps.
    Details here
    Central NJ - USA
    or, could u be driving on snow and spinning your tires?
    hehehehe =]
    Fogtown
    No, that kind of speedometer error usually occurs only on empty parking lots with a heavy foot-no snow here. =]
    Just glad to find out that this is not caused by my instrument cluster.
    Apr 2004
    Details here
    If the sensor is bad it will also effect the cruise control operation.If cruise works OK might want to look into the speedo itself.
  1. Speedometer Sometimes doesn't work
    By xtmsports in forum Electronics & Lights plus A/C
    Last Post: 03-25-2005, 08:40 AM
  2. Speedometer Problems
    By BobGardner in forum 5 Series BMW
    Last Post: 03-24-2005, 11:53 PM
  3. Speedometer error?
    By mlrwy in forum 5 Series BMW
    Last Post: 01-15-2005, 05:34 PM
  4. speedometer question?
    By 1000_eyez in forum 5 Series BMW
    Last Post: 11-12-2004, 08:00 PM
