you can lift it right up?? I didnt see any brackets on mine but it dont move at all.
I inpected the battery area underneath the rear seat and noticed that the hold down bracket is missing.
I'm not sure which one I need though.
I'm guessing #4 or #12
I can't lift it, but it can slide about 1/2" forward and back.
maybe it just needs to be tightened?
i'm not entirely sure which is missing on yours, but i'm somewhat suspect of 12 if you can rock it back and forth. if you are concerned about it, and can't see either installed, i'd get both.
Originally Posted by Garlic Breath
If you input the last 7 digits of your VIN...then work your way over to the diagram you posted above...if you look at the part number index beneath the diagram you can tell which one is for your car. If the item number is not listed in the parts index...then that part isn't used in your car.
I just went to the sight and did it...and my 1995 525iT only showed #4 in the parts list...and the "from" coumn...it says 04/1991...but that could be for the Touring only...so I would recheck that info if you own a sedan.
Click here to see an example of the diagram & part number index: http://www.realoem.com/bmw/showparts...60&hg=61&fg=30
Q
95 525iT / 97 740iL
