Results 1 to 3 of 3
Thread: Head Gasket ? 90 535
    Apr 2004
    Default Head Gasket ? 90 535
    It looks like my head gasket on my 120K 90 535i is starting to seep and will need to be replaced. It was replaced by the original owner probably 7 years ago somewhere around 60-70K.
    Questions are: Is this about right in terms of failure rate? It's been a while since I've lurked around the E34 forums but I seem to recall that there were people who had done at least 2 head gaskets through the life of their cars.
    Also should I have the valves looked at by a machine shop while the heads out? Any thing else that I should deal with while everythings apart? (Other than water pump, T-stat, new bolts etc...).
    Thanks in advance,
    Tom Der
    North Hampton, NH
    90 535
    91 M3
    05 Cooper S Works
    Pleasanton, California
    If I pulled the head for a gasket replacement I'd have the valve guides and stem seals replaced.
    Curt.
    Default Use the search function in this forum and type...
    "535i head gasket." There is alot of info related to this maybe more than you ever wanted to know from cleaning piston tops to disassembling/assembling head.
    Quote Originally Posted by Tder
    Thanks in advance,
    Tom Der
    North Hampton, NH
    90 535
    91 M3
    05 Cooper S Works
  1. head gasket on 1.6 m43?
    By billy in forum 5 Series BMW
    Last Post: 03-18-2008, 08:20 PM
  2. Re-use M30 head gasket
    Last Post: 11-21-2007, 04:14 PM
  3. milled head + euro motor = thicker head gasket?
    By 31Hertz in forum 5 Series BMW
    Last Post: 07-30-2007, 05:50 PM
  4. 525i Head Gasket/Head problems...
    By Spud in forum 5 Series BMW
    Last Post: 08-11-2005, 01:16 PM
  5. Blown Head gasket / Cracked head M50 Vanos
    By MotoMan in forum 5 Series BMW
    Last Post: 03-09-2005, 12:46 AM
