Results 1 to 8 of 8
Thread: Ah hell, I think my car is conspiring against me! :(
    Nov 2004
    What about using a reverse thread extractor? They are normally used for screws rather than bolts, but it might work. Of course it depends if you can get a hole drilled in the top of the stud. A proper stud extractor might also work provided there is enough of the bolt sticking out to get a hold of.
    Failing that I would go for the file/grinder and vice grips method You could also file it off square and use a small open ended spanner (wrench?) instead of vice grips.
    Good luck!
    netmgr Guest
    Default why all the fuss
    why go to all that hastle
    just get another engine...
  1. How the hell do you...
    By E34 530 in forum 5 Series BMW
    Last Post: 12-15-2006, 08:02 PM
  2. what in the HELL was that??
    By romus in forum 5 Series BMW
    Last Post: 11-12-2005, 04:22 AM
  3. MPG What the hell???
    By ArtemLepilov in forum 5 Series BMW
    Last Post: 10-20-2005, 03:06 AM
  4. OK, it really is conspiring against me!
    By doogie in forum 5 Series BMW
    Last Post: 12-01-2004, 03:38 PM
