I’m about to give up so if you have any idea’s, I’m desperate!
I have an 1991 BMW with an m30 engine (actually in a 735i, but I’m cross listing in hopes of better visibility), with 200k miles on it. It began running rough and finally will not run at all. The plugs were fowled (black and wet with fuel). Spark plugs and injector tests indicate erratic firing while cranking, dim flash then bright for a couple of seconds then dim again.
Here’s what I’ve tried/tested/replaced so far:
Cap & rotor
Plugs
Wires (tested, not replaced, all are ~6k resistance)
Injectors (fire as described above)
Fuel pressure is between 40 and 45 lbs and holds well after cranking
Ignition coil
Reference sensor
Air flow meter
Injection ECU
Idle control solenoid
Fuel tank is full and gas does not smell varnished
I have not replaced plug wires as I do not have a spare set around (I’m more of an early big 6 guy, I have two e28s and an e24) but I do have some concerns about the inductive pickup on wire #1. It looks fine, but if it failed, could this cause the care not to start? My other sources have indicated that this pickup is not used my the ECU, if this is incorrect let me know.
Any assistance would be greatly appreciated.
Lisle
