Results 1 to 5 of 5
Thread: Help...rev limit kicks in @ 4000
    Nov 2004
    North Carolina
    Default Help...rev limit kicks in @ 4000
    Hello,
    I purchased a 95 540i automatic a couple of months ago. Car is in need of a little TLC. I am working out the "little" quirks and problems. The latest thing I am experiencing is yesterday when accelerating, check engine light comes on for a second and power dies at 4000 rpm, seems like rev limiter. Over the past 2 months this happened maybe once, I was low on fuel and thought maybe I was a lot lower than I thought. I just changed the fuel filters 2 days ago. Related somehow? Any suggestions on where to start looking for the issue? Go to BMW and have them run diagnostics?
    The problem exists under hard or slow acceleration, @ 4000 rpm. Under normal auto shift program it shifts at about 3700 3800 rpm so not a problem. In manual mode or sport is where the problem arrises. It is only a second of power loss, car runs normal once it it has its little blurb.
    Thanks for any help!
    do a stomp test and see what the code is trying to tell you first.
    Nov 2004
    North Carolina
    Can you elaborate a little more?
    Default sure...
    Nov 2004
    North Carolina
    Great, Thanks.
  1. ABS kicks on at low RPMS
    By misfortune in forum 5 Series BMW
    Last Post: 06-28-2008, 09:13 PM
  2. 525 M20 rpm falls when reaches 4000 rpm.
    By emw525E34 in forum 5 Series BMW
    Last Post: 01-16-2006, 12:25 PM
  3. e34 worth $4000
    Last Post: 12-15-2005, 10:02 PM
