Results 1 to 8 of 8
Thread: Supercharger?!? Any good?
    Nov 2004
    Surfers - Australia
    Default Supercharger?!? Any good?
    Hi, just saw this on E-bay, does any one know if its any good? and approx how much power i will really gain? thanks every1.http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=33741&item=7934533 344&rd=1&ssPageName=WDVW
    Nov 2004
    Surfers - Australia
    Also, are there any cheep ways of gaining about 70hp?
    a statement like this generally means it's absolute ********,
    "Q: How is this powered? Electrical or belt?
    A: Neither, our product works independently from your engine, the unit is placed directly into your intake"
    if there is no means to compress air in quanitys over and above the air allready drawn into the engine it's most likely a restriction, sorta like those marine bilge blowers that are billed as electric superchargers
    nitrous is about the cheepest way to get there, till something malfunctions and melts a piston, most cheep n02 systems are for wet flow intake manifolds (like a carb or tbi set up) a correct system for a bimmers dry flow intake would have nozzles in each runner of the intake supplying fuel and n02 at the proper mixture, 70 hp wouldn't be too hard but would probably cost over $500, can't say how long the motor/driveline would last, it might not mind too much or it may cough up the head gasket on the first squease
    Quote Originally Posted by wat_sup2002
    Default This is more realistic
    If you see an offer for $ 450,-- + 95 more HP, you should forget about it.
    Better have a look on this offer for the MAF improvement.
    click here
    Central NJ - USA
    Our product is guaranteed to give your up to 75hp gain
    HAHAHHAHHAHAHHA
    Default Key word being...
    UP TO 75hp gain
    Bellingham
    A: Neither, our product works independently from your engine, the unit is placed directly into your intake accelerating the airflow through out , allowing nearly full combustion and better fuel distribution. Giving you the boost you need. Depending on which stage you get, the more hp you need , the more power the unit will output
    AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAHAH AHAHAHAHAHAHAHAHAHAH
    It's a scam, dude.
    Free power does not exist.
  1. Electric Supercharger... Any good?
    Last Post: 10-22-2007, 05:08 AM
  2. Electric supercharger
    By jordansportsfan76 in forum 5 Series BMW
    Last Post: 03-29-2007, 12:21 AM
  3. Replies: 1
    Last Post: 09-25-2005, 03:55 PM
  4. supercharger
    By m3iceman in forum 5 Series BMW
    Last Post: 03-19-2005, 09:57 PM
