also the thermostat housing, they split right on the seam on the v8s. brought to you be the same *******s that brought you the plastic m50 water pump, the cyclonic valve (pcv) on all motors built after 95 and some before, the windshield washer pump location on the e38/39.................. and many other fun annoying things
Originally Posted by
DueyT
Go figure that the one place that cheap plastic is used in a critical fail path on the car and I find it...ooops, wait a sec...the neck of the rads too...what is it with the cooling system?
Cheers,
Duey
