I could have swore he had an '89 535 when I read his post, sorry for the misinformation I provided.
You should always listen to Bill R. and Winfred anyway, some of us aren't worthy....=)
Apologies,
Jr
the m20 bar doesn't get loose, DO NOT OVERTIGHTEN IT this will break the boss it's screwed into, i have a fix but i am not sure if it can be done with the cam installed, the bar can be sparayed out with carb cleaner and the holes poked clean with a pick or other pointy object. crappy idle with the cap off is normal, the m20 has a closed crank case and any blow by is sucked into the intake, any signifigant air leak will screw with the injection system just like any other vacuum leak
Apologies,
Jr
yea right like i don't **** up
[QUOTE=Robin-535im]You should see the power it has now... without all that pesky oil drag on the cam shaft!QUOTE]
Maybe with the crank though.
i really appreciate everyones help. i cant win for losing. i figured i would check the oil press, borrowed a co-workers' oil press gauge for the weekend. removed the sending unit to find that his set does not have the metric coupler to fit my motor. drove around all day to no avail. checked several stores,nobody has it. does anyone know where i can get the adapter/fitting to check my oil press? again thanks
i just use a generic add on op gauge they usually come with several adaptors and enough tubeing to get it to a safe area to watch, i've been using the same one for several years and they are cheep enough to throw away
Originally Posted by jiminEcricket
Originally Posted by winfred
appreciate the suggestion , i'll give that a shot. otherwise i'll spend the rest of my life trying to find the correct adapter. thanks![]()
