Recently I wrote in about my right rear tire (255/40 ZR17) wearing out on the inside. The wheel was toeing out and I wanted to know whether there was any way of aligning it to toe in. The answer was "no".
Will replacing worn Pitman arms fix this problem?
Roman
they do have offset bushings for the rears. They are usually to correct the camber issue when lowering the car but I believe if you install them a little different you may be able to point them whatever way you want to. Is your car lowered? FYI: It is completely normal for these cars to wear the inside of the rear tires even brand new from the factory.
