Results 1 to 10 of 13
Thread: Timing chain noise? Advice?
    Lexington, Kentucky
    Default Timing chain noise? Advice?
    I think my timing chain is making a bit of noise. I get a raspy rattling sound when reving from idle. BTW, all pullies and belts are new.
    After reading and checking the archives a bit, this problem sounds like a loose or worn timing chain noise. The Bentley seems to make it sound as if it is a difficult job with special tools to do anything relating to the timing chain.
    Not sure if I want to tackle. Assuming this is the problem area. What is invloved parts wise and time wise for an indy to tackle?
    Thanks in advance
    baton rouge, loserana
    to do it right i would do all of the sprockets and rollers and guide rails, the way to get to all of that is remove the front cover of the motor and to remove that you loosen and lower the oil pan and remove the head as the cover is sandwidged between them
    NC
    Default How's the hydraulic tensioner? That could be causing you some grief...
    I think my timing chain is making a bit of noise. I get a raspy rattlting sound when reving from idle. BYW, all pullies and belts are new.
    Thanks in advance
    It quietened down my M42 318iS...
    Bill B.
    95 525i
    that'd be my best guess, they came out with a updated unit for the m50
    Quote Originally Posted by billb
    Lexington, Kentucky
    Default Can you tell me more about the updated tensioner unit?
    Can you tell me the part numbers etc. and is this something I can do myself? if I rememeber correctly from Bentley, there is a tensioner with a spring that is external to the engine. I assume this is what you are talking about. Anything else looks like really big job if the head must be removed.
    on the m50 it just unscrews from the head above the ac compressor and you just screw a new one in paying attention to the position of the notch on the end so that it fits onto the tension rail, i think it's real cheep under or around $20
    Lexington, Kentucky
    Default Thank You. However...
    I think I will order the part or parts from Patrick at BMA. It may not be the problem. However just to be on the safe side I will go ahead and do it.
    Even so, I am still not sure, Is it a update "kit" or do I need just the spring or individual parts? From My ETK there appears to be several individual items. yet no mention of an update "kit" that I can see.
    I Really appreciate your help. It looks like a simple job once you have the correct parts.
    Lexington, Kentucky
    Winfred- once more please -
    Default huh?
    Default Is the F__kin tensioner 1 part????
    sheeesh...hydrobud goin on down there?
  1. M51: timing chain needs replacing?
    By mitch2k in forum 5 Series BMW
    Last Post: 10-10-2006, 12:48 AM
  2. Timing Chain Alignment on the M30
    By myles in forum 5 Series BMW
    Last Post: 05-05-2006, 12:17 PM
  3. Does an e34 have a timing belt or chain?
    By thunderman in forum 5 Series BMW
    Last Post: 03-29-2004, 04:36 PM
