Results 1 to 10 of 10
Thread: Lower door trim removal
    Default Lower door trim removal
    Just wondering if anyone else has removed the lower door trim. Mine appears to building up rust in that area. I want to clean it up but I'm wondering if I can re-use the old door trim. The trim appears to be in good condition.
    thanks
    new ones are like 20 bux each, havent replaced mine yet.
    Minnesota
    Those door trims are a real rust trap, pull them off and inspect your door bottoms. They may be rusting. I had the bottoms of my doors sandblasted and repainted, with new door bottoms trims installed. The trims are usually not re-usable, they break down internally. Pull them off, you'll see whether good or not.
    Mar 2004
    MASS
    Default The rust is usually from the trim
    The bottom trim has metal inside. What happens is the trim splits, the metal rusts and it shows up on inside of the door or it starts the door to rust too. I bought all four door bottoms and will replace before winter. You'll also find the door side molding is made the same. I have 2 of those that are starting to rust too.
    SCHUYLKILL COUNTY, PA.
    Default are the door bottoms a dealer item?
    does bma have them?
    what color are they?
    thanks
    tim s.
    Minnesota
    Black, BMA should have them.
    Default think it's better to remove the door trim all together...
    and not replace them b/c they seem to start rust? not sure how it will look though. i'm going to buy some before i start ripping off the old ones.
    thanks,
    Quote Originally Posted by Gooch
    Default BMA has them for 21 bux each, do these swap right out or
    are they glued or something? How bout putting some sort of grease in the groove before popping the new ones on?
    LA, California
    Default i bought new ones
    Mine were completed worn out. to the point that the plastic and metal were chipping. yah they are rust traps. I got new ones from BMA. They slide into a groove starting at end of the door.
    Default Lower Door Trim
    I changed mine this spring. The old ones are not worth trying to salvage. The new ones I bought for my 95 were grey and had to be paonted. They were also a B*tch to get back on after the doors treated for rust.
    There are two types of trim. The later cars have a rigid piece and the older ones are flexable. BMA has both and neither have any metal in them.
  1. help-looking for m5 lower door trim
    By weazman187 in forum 5 Series BMW
    Last Post: 12-01-2008, 09:44 PM
  2. Lower door trim - where to buy?
    Last Post: 04-10-2007, 09:28 PM
  3. iso: lower door trim PN's
    By ILoveMPower in forum 5 Series BMW
    Last Post: 09-12-2006, 10:04 PM
  4. lower door trim -95 540
    By scott540 in forum 5 Series BMW
    Last Post: 03-25-2006, 12:53 PM
  5. Lower Door Trim
    By clhorton in forum 5 Series BMW
    Last Post: 01-19-2006, 03:31 PM
