anybody have this happen before? my cruise control doesn't work all of the time, sometimes it will work, but when going up hills, it will drop down about 5 mph before tryign to maintain speed, its quite jerky. most of the time, it won't work at all, even when its making noise under the hood. i'm trying to figure out if this is something relay related or related to the actual actuator. david chen....if you read this...did your actuator do this before you cleaned it out inside? right now, i've just got the electrical cable to the actuator disconnected so it isn't running all the time. thanks.
