Results 1 to 10 of 12
Thread: How does Sachs Sportin Kit compare with Bilstein/H&R?
    Canada, ON
    Quote Originally Posted by Anton CH.
    I need new suspension bad (my shocks are leaking). These seem to be one of the most popular suspension upgrades, how do these two compare?
    I drove both cars, the Sach kit is great, might not lower as much.
    They are both a stiff drive, but the sach kit isn't as stiff. But it is stiffer than the bavauto springs....
    Tires makes big difference in ride quality. I went from Nitto Extreme 555 to Bridgestone RE730... about the same sidewall height... man! What a difference! It is much more bearable.
    Nitto was hard as a rock when hitting potholes, bumps anything with sudden change in road. Bridgestone soaked it up and never jarring.
    When I said sidewall thickness... that's because I went from 235-45R17 to 225-50R16... not the right 16" tire for E34... 3/4" too small but I want to use up the tire before I buy new set.
    By the way, I got Eibach and Bilstein Sport... next step is thicker spring pads... I think this will cinch it. Old pad is so worn out.
  1. FIB Bilstein ??.
    By mikey535im in forum 5 Series BMW
    Last Post: 07-18-2010, 09:42 PM
  2. Oil Pressure test on M30- How does yours compare?
    Last Post: 09-02-2006, 09:05 PM
