Originally Posted by jj7
My previous 520i,91 used to open the locks from the rear trunk, with my current 525i, 94 if i try to do that it won`t work it will only open or close the trunk only,won`t activate the central locking.is it normal or am i missing something here?
Jeff,gooood to have you FOCUSED and sharing valuable thoughts on the forum....Re-synchronize,is that something i can do or the dealership is the only place to be???should there be a relay,switch, or computer reprograming required to have it done...
thnx a mil
To re-sync the locks..insert your key into the passenger door's lock and turn it to the re-sync position (see pic below) ... or whatever direction that double locks the doors...hold the key in that position and listen for each lock actuator to close. (this also happens to be the same procedure to roll up all the windows and sunroof from outside the car) Once all the locks have actuated...go over to the driver's door and unlock the car. Do this at least two times to re-sync the locks. If it doesn't re-sync...out-of-sync-locks are not your problem.Originally Posted by jj7
Q
95 525iT / 97 740iL
If/when re-synchronizing doesn't work, pull down the truck lid liner and make sure the linkage to the lock actuator is connected. Mine has a habit of coming disconnected.
Paul Shovestul
Originally Posted by Qsilver7
Qsilver7, man you put a smile on my face,just did the procedure and worked like charm...Paul the re-sync worked as much as true,but it does the locking for the doors,but when i tried to open it didn`t, is this limited to locking but don`t include opening of the doors?? sorry to bother you but i forgot how it was with my old bimmerOriginally Posted by Bellicose Right Winger
Appreciate it greatly
I think you are saying you can lock doors from truck lock but you can't unlock doors from trunk lock. In US spec cars, you should be able to lock & unlock all doors and the trunk from either of the front door locks or from the trunk lock.
Note that there is a trunk lock position that keeps truck locked all the time. If trunk lock is in this postion, then trunk will not unlock when the doors are unlocked with the front door locks.
Paul Shovestul
Paul Shovestul
Man you got me dissy,have you noticed how mind twisting it is![]()
, but i got the point and is very appreciated.The locking through the trunk is active, as for unlocking its not working...my car is a japanese imported,do`no much how things work for them,the synchro worked on the spot, i will try though to activate the unlocking too
thumb`s up
jj
[QUOTE=jj7]If trunk lock is in this postion, then trunk will not unlock when the doors are unlocked with the front door locks.
Paul Shovestul
JJ, Paul means that the trunk lock keyhole must be in the vertical position when you syncronise all of the locks. (see photo)
Also I just checked my cars and on the '89 525i I can lock the trunk and all the doors from the trunk lock but like yours it won't then unlock the doors from the trunk. I'm pretty sure I used to be able to unlock from the trunk. Maybe the trunk lock has something wrong with it - but it's no big deal.
On my '94 540i I can lock and unlock everything from the trunk.
I think also that when you lock the doors from the trunk, the doors are not "deadlocked", although I could be corrected on this point.
Phil
[QUOTE=Phil Sanderson]tnx Phil for the follow-up, the position of the key hole was as shown above, i tried to close the window and it actually did close it,they are synchronized to close now,about opening i will check if japan spec can do that or not...Originally Posted by jj7
