take the phone off.. then the pull up on bottom piece.. it will pop out.. and iss fixed to the black plastic with screws... when you remove it will have drilled holes.. but looks much better then with the phone... there is a support piece that is in there.. if you remove it there will just be the tray.. but with holes in the corners (for the routing of wires)...
