Results 1 to 10 of 16
Thread: 92 535 5spd - Pops Out of 1st Gear
    Default My 5 speed did this when I first got it. Mobil synthetic gear oil change fixed it.
    Hasn't happened since. MTL went in late last year.
    erased due to slander
    Mar 2004
    Toronto, Canada
    Thanks for the reply guys.
    I should have stated that a used tranny might have the same issues, vs a rebuilt one which would obviously have been overhauled.
    Still looking for a rebuild procedure.
    Rod
    Default Before you rebuild your tranny....
    Chech yer motor and tranny mounts. Swap fluids as Martin B - geeenuius - suggests. Rebuild your linkage with new parts. Theeeeen, if it still sucks, put in a different tranny. But not before.
    BTW, 2nd gear syncro tends to go first - before the 1st gear synco. If 2nds' fine and first isn't, I guess you can fix it with one of the above.
    Jeff
    Quote Originally Posted by talltorontoguy
    Rod
    Bellevue WA
    86 Porsche 951 - Track Toy
    Mar 2004
    Toronto, Canada
    Thanks for that tidbit of information. I'll try those suggestions first.
    In the event they don't work... anyone have a line on a used 5 speed?
    Rod
    Default I have a spare one in my garage
    Email me if you think you're interested. It's got some miles but serviceable.
    Jeff
    Bellevue WA
  1. Loose shifter knob - pops off
    Last Post: 10-19-2010, 06:09 AM
  2. manual transmission pops out of gear
    Last Post: 12-04-2007, 09:36 AM
  3. Upper Radiator Hose --- Swells then Pops Off
    By Evan in forum 5 Series BMW
    Last Post: 06-25-2007, 07:17 PM
  4. '92 525 Transmission Pops Out Of Drive (GM-4L30E)
    By imnprsd in forum 5 Series BMW
    Last Post: 10-15-2005, 04:48 AM
  5. Fuse #17 pops and causes car to not turn over
    By Asharus in forum 5 Series BMW
    Last Post: 08-05-2004, 10:19 AM
