Thread hijack! Got a soft brake pedal Q for you guys--
The question is regarding my 330 - Don't get the kind of experience and support I need in the e46 forums on some of this stuff.
Had a Driving School at Lime Rock last weekend with Drew. GREAT GREAT TIME! and the 330 was incredibly well suited to the task. But my brakes are a bit different now---
Starting the 3rd and 4th sessions, I noticed the pedal started out a bit low, and pumped up over the course of the first lap, then remained nice and firm for the duration of the session. Now, in regular driving, the pedal engagement is a bit lower than before the track day. Also - if I touch the brakes, then off, then on again, the pedal pumps up quickly. There is no bleed down in pressure - i.e. if I get on the brakes and hold, it does not move downward at all. It just seems that the first engagement is low.
These are stock (large) brakes on a 330i, stock pads. I had bled the brakes a week prior to the School - new ATE blue. I bled them again Friday (2 days ago) thinking that would clear the soft pedal issue. I also bled the clutch Friday night, as I finally swapped out the CDV. No change in pedal behavior. The front pads look perfect (haven't even gotten through the beveled edge yet - 6K miles on them). The edges of the rear pads look a little bit ragged. There is a LOT of brake cooling up front on this car..... Inspection Friday night revealed no leaks or soft spots in the (stock rubber) lines. I supposed I could have missed a soft spot - I only had the brake bleeder pumped to 10psi, they are basically brand new.
What's the likelihood of pad deposits causing this sort of behavior? What are other possibilities?
Thanks much--
--Micah O'C
'17 M2 6MT, Mineral Grey
'04 330i ZHP
'88 M5 2791445
'92 M5T BL01001
formerly '90 535iM, '92 525iT
