engine is warmed up?
Originally Posted by billb
Would either of you guys be "willing" to let me borrow your AFM for a few minutes? I'm trying to find out why my 525 goes through this wonky rich running thing, and I've tested/replaced everything but that. New FPR, new O2 sensor; checked and verified correct operation of ECT, IAT, TPS, CPS; all injectors firing (and clean!), all coils firing. I'm nearing wits' end...
I'm in the phone book, under Bass William, or shoot me an email. It's in my profile. I'm at work this morning (Saturday) until noon, then free from noon -4, and most of the day tomorrow (Sunday).
Thanks guys!
Bill B.
95 525i
i have no idea where the apex area is, but i'd be more than willing to loan you mine if you were in dallas.
Originally Posted by Bill R.
Bill B.
95 525i
I pulled the cover off the connector and am backprobing the connections. Getting ~1V at idle, and it increases as engine speed goes up. Checking O2 sensor though at the DME, I am only seeing 0.45V...it's not changing, even when the idle is hunting up and down. Isn't 0.45V the midpoint for stoichiometric operation? I can't get it to run long enough for me to crawl under and backprobe the O2 sensor connection, but with the sensor out and using a propane torch, I was able to get it to go back and forth around the 0.45V point, all the way up to 1, down to almost 0. Hmmm, maybe that's where I need to look...if it's not fluctuating, it's not adjusting. Wonder if I've got some wonky wiring going to the DME from the O2 sensor?Originally Posted by Bill R.
Bill B.
95 525i
sensor is up to temperature and working correctly the voltage fluctuations are pretty rapid.. about 3 to five times a second on cars that are adjusting correctly.... What happens if you disconnect the throttle position switch and then run the car? Not the maf just the throttle position switch
http://bimmer.roadfly.org/bmw/forums/e34/5802947-1.html
Bill
You might want to check this link, looks like a similar problem to yours except on a V8 engine (hope this might help you).
Steven G.
but let me try it again...Originally Posted by Bill R.
Bill B.
95 525i
Pulled a plug..here's what we look like after about 10 minutes total time of running at idle. I'm really suspecting the fuel at this point...it's just too dang coincidental that it's happening right after a fillup (when I was almost empty in the previous tank). Really considering buying several 5-gallon gas cans, siphoning this tank out, and starting fresh.Originally Posted by billb
Bill B.
95 525i
so this happened right after filling up??
