Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: wtb: 20mm spacers
    Renton, WA
    Quote Originally Posted by Mobius
    If you're going to run the 'right' hubcentric spacers, as you should, you'd better get some damn high quality wheel bolts, and you'd better be damn religious about checking torque with a good torque wrench on a regular basis.
    The weight is not supported very much at all by the lug bolts. Checking wheel torque goes without saying- having lug bolts come loose is bad news with or without spacers.
    Really, you should buy wheels that fit your car.
    That's best, but spacers are not a problem (again, if done right). Properly bolted down, the hub-spacer-wheel is essentially one piece and is not much different than the hub-wheel unit.
    1992 535i TCD-s2
    Wash DC Area Fairfax VA
    Why don't you sell the M3 wheels and use that money to get wheels that don't need spacers and such. I had some M3 contours from my M3/4that I had just lying around and asked the same question you are because I wanted to put them on my beloved 530iT. Decided to sell and use that money to get some correct wheels
    SCHUYLKILL COUNTY, PA.
    Default they where a gift from my nephew!
    tim s.
  1. Offset Question: 35mm vs 20mm
    Last Post: 02-13-2008, 09:25 PM
  2. e34 rear swaybar question - sizes over 20mm
    Last Post: 04-05-2005, 06:10 AM
  3. Opinions wanted on rear 20mm swaybar
    Last Post: 03-30-2005, 05:26 AM
  4. are 20mm spacers hard on wheel bearings???
    Last Post: 04-11-2004, 11:02 AM
  5. Has anyone tried the 20mm rear bar ala e34.net?
    By Cacatfish in forum 5 Series BMW
    Last Post: 03-23-2004, 04:35 PM
