Results 1 to 10 of 10
Thread: How do i calculate change in RPM from one ratio to another?
    NYC
    Default How do i calculate change in RPM from one ratio to another?
    specifically 3.46 to 3.91
    NYC
    Default Im runnign 235/45 17" wheels and I'm trying to figure it out at 80 mph
    Quote Originally Posted by Jason
    Default multiply your rpms by 1.13
    Default You're welcome to try my 535 with the 3.64lsd.
    I replaced the open 3.46 with a limited slip 3.64 this spring. It seems to be great. First gear is useable around town.
    I think Robin has a 3.91 in his 535 5 speed. The previous owner converted it to a 5 speed leaving the differential.
    erased due to slander
    Default I did this a while back too:
    I've got the 3.91 in my blk/tan 1990 535iM, it was converted from an automatic like Martin said.
    Did you see the post from Jeff N asking about diff ratios? Some good input from the board on what it's like.
    If you look at the chart, 1st w/3.46 is pretty close to 2nd w/3.91.
    The top line of each gear is 3.46, bottom is 3.91
    EDIT: I made a mistake in the calculation... let me get it right and I'll repost.
    Robin
    72 Chevy K10
    01 E39 M5
    NYC
    Default How do you like it? Are you that close to 4k @ 80 mph?
    Based on Jeff's formula im looking at 3400 rpm... is that accurate?
    NYC
    Default Now why didn't i think of that? thanks
    NYC
    Default I appreciate the offer. Next time im on your side of the county, i'll look you up
    Quote Originally Posted by Martin in Bellevue
    Default Just checked: 3400 RPM in 5th @ 80mph
    I couldn't say that one ratio is better or worse, it just places your gears in different ranges. I personally liked 3rd with the 3.46 better because you could pass on the freeway at the high end of 3rd. Now I usually take people in 4th, and the car's not yet in the max power place at the beginning of the pass. However, I really like 2nd w/3.91 around town because you can pull real hard through 2nd yet not really be speeding at the end.
    Robin
    72 Chevy K10
    01 E39 M5
  1. 3.07:1 axle ratio?
    By Ross in forum 5 Series BMW
    Last Post: 04-03-2008, 01:44 PM
  2. M20 compression ratio???
    By luke01 in forum 5 Series BMW
    Last Post: 01-28-2008, 09:41 AM
  3. What ratio is my diff?
    By RiggsyB in forum 5 Series BMW
    Last Post: 08-07-2006, 05:47 PM
  4. help me please!!! BMW gear ratio?
    By DENVER in forum 5 Series BMW
    Last Post: 03-09-2006, 01:52 PM
  5. Replies: 1
    Last Post: 10-08-2004, 11:52 PM
