Results 1 to 10 of 10
Thread: Question for the "switch" gurus.
    SF/Bay Area
    Default Question for the "switch" gurus.
    I'm sure this is stupid question, but can you use the same window switch for the driver (auto up & down) for the other 3 windows?
    Thanks, Keith
    Yes, no question is stupid! The only stupid question is the one you dont ask and fÜck the whole thing up.
    SF/Bay Area
    Quote Originally Posted by Keith
    Thanks, Keith
    Wellllllll, after checking the ETK, it seems that it's the whole cluster of 4 switches, so I guees this means you CAN'T replace just 1 switch if you needed too, correct me if I'm wrong.
    Keith
    Bellingham
    Can't, nor should you ever need to. I've never seen a mroe overbuilt switch in my life. I was in awe of it when I took it apart to clean it out a while ago.
    All four of your windows should have auto-down - just tap the switch quickly. If a switch stops working, it's really easy to pop the whole cluster apart and clean them out.
    single cluster?? i have to do my homework now.
    SF/Bay Area
    Quote Originally Posted by Mobius
    I realize that I have the "tap down" feature on all of them and have the "tap up only" on the drivers window.
    My question was, can you make ALL FOUR do the same as the drivers window?
    Gulf Coastal Mississippi
    Actually, the switch does not control the automated window up/down function... the main control box under the back seat, drivers side, controls the auto up/down of the windows. I just forgot the technical name for the part... someone help me out... It's the same unit that controls interior lighting, dor locks, etc, and is located right beside the main relay control unit... Hell, I've got 3 or 4 of 'em sitting in the garage... just can't remember the name... anyway, that's what determines if you have the one touch up/down feature. Hope that helps.
    1991 535i 176k (under serious surgery: repaint, interior swap, manual conversion, etc.)
    1993 750iL 132k
    Default can you take it apart? My pass side has some glitches.
    Quote Originally Posted by JeremyT
    Minnesota
    Jeff,
    If it's the switch that has a glitch and can't be fixed, you can get a new switch assembly from BMA for about 50 or 60 bucks.
    Bellingham
    Quote Originally Posted by JonE
    Jeff,
    Bah - no need. Seriously, aside from a direct hit with an ice pick, the switch cluster should be damn near unbreakable. Pull it out, take it apart and clean the contacts with a little alcohol, then lube 'em up with some dielectric grease.
    As far as the auto up/down goes.. If I recall correctly, the switches are all identical in operation (there's nothing different about the driver's window switch) - so ALL the auto up/down is probably handled in the control box.
  1. Brake Pedal "Tapping"/"Knocking" Sound - 89 535i
    Last Post: 10-16-2007, 07:12 AM
  2. "BC" switch and In-dash OBC display
    By SnakeyesTx in forum 5 Series BMW
    Last Post: 08-09-2006, 03:23 PM
  3. Replies: 5
    Last Post: 03-15-2006, 11:31 AM
  4. Center Console "Toll" Switch Broken
    By JMI in forum 5 Series BMW
    Last Post: 03-03-2006, 12:50 PM
