Results 1 to 9 of 9
Thread: Rough Idle
    Default Rough Idle
    My 95 530ia with 156K was giving the check engine light. After numerou$ visits to my indy, replaced O2 sensors, decarbonized, disconnected the cold start air pump, replaced the air flow sensor, it was running fine.
    Now, 3-4 months later, I have episodes where the engine idles roughly while in gear at a light, a/c makes no difference, putting in neutral helps a little but still there, although it runs well as I accelerate. At times it will be fine, other times it's back. It seems independant of engine temp or climate.
    Any thoughts on where to begin?
    John
    Oh yeah, the stomp test shows all clear
    John
    PA
    Quote Originally Posted by john neuhoff
    John
    Idle Control valve?
    Default Nikasil or Ausil block?
    Idle Control valve?
    Bellevue WA
    86 Porsche 951 - Track Toy
    I'm not familiar with that, I'll look in Bentleys. Any clues to offer?
    John
    The block was replaced at 100K, so alusil, right?
    John
    Default check for vacumm leaks,
    also could be the PCV plate at the back of the intake... total PITA to fix but only 40 bux.
    Apr 2004
    Raleigh, North Carolina
    I have the same thing, very rough idle. I'd think it was leakdown if I didn't know it was a alusil block replaced sometime in '98 or '99. I've got new motor mounts on order (my PS pressure hose was leaking all over it), but it's probably something more involved - idle control valve or f*ed up timing or something.
    Ex-Calypso Red 540i owner
    thanx
  1. help re rough idle...
    By pong in forum 5 Series BMW
    Last Post: 09-09-2007, 11:34 PM
  2. Rough Idle
    By hinchcliffe in forum 5 Series BMW
    Last Post: 08-27-2006, 10:12 PM
  3. Rough Idle - 94 525/5
    By vaaccess in forum 5 Series BMW
    Last Post: 11-17-2005, 10:31 PM
  4. rough idle...
    By liquidtiger720 in forum 5 Series BMW
    Last Post: 04-18-2005, 09:50 PM
  5. Rough Idle....???
    Last Post: 04-06-2005, 02:51 PM
