Hi, I`m New To This Forum, And Was Hoping Someone Could Help Me With This Problem.
I Have A 91 M5 3.6 With 118,000 Mls On The Clock. The Service Record Shows That It Had A New Engine Fitted At 60,000 Mls.(i`ve Had This Confirmed By The Dealer Who Carried Out The Work.) The Problem Is That It Runs Rough When Idling And Cruising. It Doesn`t Cough,missfire Or Want To Cut Out, It Just Sounds Lumpy.as Soon As You Let The Clutch Out And Start To Move Or Sit Still And Rev The Engine Its Fine.
Its Starting And Switching Off Ok.i Put It Into My Local Bmw Garage And Thay Checked The Valve Clearences, Injectors,exhaust Emissions,engine Management System Codes, All Ok. The Hoses From The Inlet Manifold To The Engine Were Checked And Some Replaced But Made No Difference.
It Was Also Suggested That When You Take The Oil Filler Cap Off With Engine Running That It Should Stop. Is This True Because I Tried That An Mine Doesn't Stop?
I Would Appreciate Any Suggestions On This Matter As I Don't Want A Small Problem To Turn Into A Big One!
Cheers
