Results 1 to 10 of 17
Thread: how to get fan clutch off??? help
    Aug 2004
    detroit
    Default how to get fan clutch off??? help
    i am attempting to replace my water pump, but am running into the problem of how to get the fan clutch off, have no idea how to get it off, any ideas?
    counter clockwise, you might have to make a "special" tool, let me see if I have one hosted somewhere for you to look at. Mine is simpler than Winfreds
    Default special tool
    Aug 2004
    detroit
    Default where can i get this tool?
    i already started the job, and i need this tool to finish im assuming, so where can i get it????
    Minnesota
    Quote Originally Posted by kyleN20
    I didn't need Jeff's Orc weapon/tool when I did mine. Have you tried getting the open end wrench on it and banging slightly harder than "lightly"? Remember, it is threaded opposite. Otherwise, people have tried holding the belt up a bit to tighten it while "banging" on the wrench.
    Default Mine was WAY tight,
    and I had to make something quick so I took a piece of steel and made it with a drill and grinder, took a couple minutes. Tried other things like screw drivers and even clamped vicegrips on the pully (that suceeded in busting it to pieces), not recommended.
    Personally, I take off the belt. Put a strap wrench around the water pump pulley so that I can push on it. Next, take the 32mm spanner (thin, and not 34mm), put it on the nut, and pull. Having the push pull allows you to get some torque on it without hammering the spanner where experience helps and murphy's law quickly asserts itself. You only have to loosen it a little BTW, as once the threads move, you can just turn the fan to loosen it up the rest of the way. Be ready to grab/catch it, otherwise it will fall straight down and perhaps ding up one of the fan blades or the rad.
    ps ramp is ok, be goddamned careful if you're on jackstands trying to get that nut off. oh yeah, spray the nut with wd40.
    Default strap wrench....
    so thats what I could have used it for...DOH!
    Put a piece of cardboard between the fan and radiator.
    Minnesota
    The threads for that bolt are opposite turning to get off. I think it is a 34mm thin open ended wrench required, I got mine from a bicycle supply house, about 5 or 6 dollars. Put the wrench on the nut and wack with a hammer (righty loosey, this time) and it should come right off. Some have had trouble getting it off, though.
    Good luck
    Default 1 1/4 inch wrench if I'm guessing correctly.
    Quote Originally Posted by JonE
    Good luck
  1. How can u tell when clutch is going?
    By barry 90 525i in forum 5 Series BMW
    Last Post: 12-31-2008, 07:11 PM
  2. M30 Fan clutch.
    By aston_jag_tech in forum 5 Series BMW
    Last Post: 09-15-2008, 12:05 AM
  3. Think I need a new clutch.
    By bbig119 in forum 5 Series BMW
    Last Post: 10-02-2006, 03:45 AM
  4. Doing my clutch, have ??'s
    By brodee in forum 5 Series BMW
    Last Post: 05-04-2006, 07:17 AM
  5. Clutch? Need a little help.
    By dbals in forum 5 Series BMW
    Last Post: 02-21-2006, 11:14 AM
