Results 1 to 3 of 3
Thread: Advice wanted: Windshield Replacement
    Mar 2004
    Toronto, Canada
    Default Advice wanted: Windshield Replacement
    Can anyone recommend a glass shop in Toronto / Buffalo / Niagra that knows what they're doing with the E34 windshield?
    I'm looking for a shop that can supply and install an aftermarket windshield at a good price. I've heard horror stories about wind noise and water leakage and so I want to be sure I only do it once.
    Should I use the generic gasket (anyone have pics?), should I order all new moldings, seals, etc?, or should I re-use existing parts?
    Rod
    The only tricky thing about it is the trim.
    The seals are fairly strightforward, although windshield work is definitely best left to the professionals. The main issue to debate is whether to install the trim clip system as is standard on your car, or go a different route. 99% of windshield guys who are not bmw guys, are going to look at those clips and say WTF!!
    Personally, I think the trim clip system sucks, and I bet 90% of the problems that come as a result of installing a new windshield are as a result of improper clip installation.
    The way I went, on the advice of my window guy (with much experience on e34's- he subcontracts to one of our major dealers and supplies all the local indies), was to install the windshield normally, without the clip retainers under the glass (potentially messing up the seating and seal), and then use a special double sided foam tape to install the trim. The tape is a specialty product in the windshield industry, and is pretty common, made by 3M. It is *very* strong, and keeps the trim on very, very tight and flush. It attaches to the glass on the bottom, and the trim piece on the other. Additionally, it gives one more airtight barrier, which eliminates airflow under the trim- the cause of most of the problems.
    Better yet, if you want to take the trim off and reinstall it without breaking it, you just use a razor blade to free it, and a solvent to reprime it, new tape, and voila.
    Houston TX
    had my 530's windsheild replaced and bought the clips from BMW and handed the clips to the guy installing windsheild......then watched him..he understood and everything went really good. The trip really needs to be tight..really tight..guess the tape would work but my preference would be new seal and new clips.
    Callen 91 535 94 530i
  1. windshield rubber replacement
    By Kibokojoe in forum 7 Series BMW
    Last Post: 12-30-2011, 07:30 PM
  2. e34 windshield replacement.. $500! Really?
    By jbraswell in forum 5 Series BMW
    Last Post: 05-16-2009, 04:08 PM
  3. windshield replacement e34 advice / instructions
    By gymkata in forum 5 Series BMW
    Last Post: 07-07-2006, 10:57 AM
  4. Leaking Replacement Windshield
    By DallasBill in forum 5 Series BMW
    Last Post: 07-11-2004, 02:18 PM
