Results 1 to 10 of 10
Thread: loud clucking noise
    Sep 2004
    Default loud clucking noise
    hey guys, i wondering if you guys could tell me what is this loud clucking and griding noise coming from underneath my 1989 e34, it occurs on take off and when i am slowing down, pls help, thanks.
    Loud clucking? Perhaps a chicken in the boot?
    Sorry I couldn't resist...
    any more info on that noise? more details man.
    Bellingham
    Very likely to be your driveshaft flex coupling, or 'guibo'.
    The clicking is it hitting the gear selector shaft. If your shifter is jerking with the clicks, you've found the problem.
    If this is the problem, get it taken care of soon - it's about to fail completely and make driving very... 'interesting'...
    Could also be a bad u-joint in your driveshaft - but typically that's associated with some very pronounced vibrations, usually in the low-end of second gear.
    Sep 2004
    hey guys thanks, i was driving the car to the shop, when the vibration became serious and i was going up an incline and the car just stopped moving, i think the shaft is broken, if so anyone know where i can get one preferable a good used one thanks and how much you think it will cost me.
    Bellingham
    http://www.car-part.com for used... There's a couple places to find them new - prices are usually around $500.
    How have you come to the conclusion that the 'shaft is broken' though? Seriously. It's probably your guibo.
    Sep 2004
    i really dont know, cuz i asked a friend and he said that its broken, and when i put the car in drive it wont move, i know the center bearing is gone, but can the guibo be the cause of it not moving?
    Bellingham
    Not moving? It's pretty difficult to imagine a driveshaft or the guibo causing the car to not move - at worst you should just get some impressive shaking and (in the case of the guibo) a noise like someone is taking a hammer to the underside of your car.
    You need to get under your car and inspect some things.
    Minnesota
    Is this car an automatic. If so, you might have a problem with the transmission.
    Default the clucking kinda sounds like driveline more than trans.
    hopefully its just a guibo. get it in the air and have a peek, a kurb or ramps may not be enough to see what all is gone.
  1. Loud Clicking Noise
    By Golgade in forum 5 Series BMW
    Last Post: 07-31-2008, 04:51 PM
  2. Loud Clicking Noise
    By Visions in forum 5 Series BMW
    Last Post: 06-25-2007, 07:26 PM
  3. Loud clicking noise when idling.
    By 92E34 in forum 5 Series BMW
    Last Post: 10-15-2006, 11:40 PM
  4. A/C makes loud noise (rpm-related)
    By ILoveMPower in forum 5 Series BMW
    Last Post: 06-25-2006, 11:08 AM
  5. Loud buzzing noise after cold start. 93` M5
    By NH004 in forum 5 Series BMW
    Last Post: 04-09-2005, 11:29 AM
