Thread: White cloud and rough idle at startup.
    Sep 2004
    Northern Europe
    Default White cloud and rough idle at startup.
    Hi guys.
    When the car is cold and I start it, I get A LOT of white smoke coming from the exhaust. This is combined with very rough and uneasy idling. When I rev the engine a bit, it settles and then runs fine. What the fudge can be wrong?? I have a diesel, FYI.
    I also have some white fumes when the engine is warm, and somebody asked me if I was burning engine oil, and somebody else asked if I had coolant leaking into the engine.
    Hmmmmmm. Any ideas?
    Aug 2004
    Dubai
    check your pistons oil rings they are warn out. so they evaporate the oil in the manfold which drips in the valves in the night and burns at once in the morning. so you have to change the rings or simply overhole job is what you need.
    Sep 2004
    Northern Europe
    Ok, thanks.
    I will look into it. Does anybody disagree with this explanation? (no offence, hehe)
    what is the weather like where you are runing this engine?
    Central NJ - USA
    all diesels run rough when cold....is this your first diesel? did the problem just start? a little more info couldn't hurt =]
    Sep 2004
    Northern Europe
    The problem is relatively new. Yes, this is my first diesel (or first car, for that matter). The weather here in Northern Europe is pretty cold, ca. 10 degrees Celcius, but not that cold. I drove it to Southern Europe this summer, where it got very hot! In fact, this is where I started noticing the problem.
    When the car is up and running, it runs like a charm, no issues here. It is only in the first 1/2 minute or so that it sounds like it is really struggling to keep going. Once in a while during this 1/2 minute it also chokes. But apart from this it runs smooth as butter.
    The engine has 325.000 km on it. It is a lot, I know, but apprx. 80.000 km's ago the engine was taken apart and got the royal treatment!
  1. M60 Rough idle, blue smoke puff on startup
    By bimmo_2007 in forum 5 Series BMW
    Last Post: 02-16-2010, 03:58 PM
  2. 1995 525i runs rough at startup
    By ruffbunch in forum 5 Series BMW
    Last Post: 09-09-2006, 08:08 AM
  3. Letting engine idle a bit on startup = good!
    By Interceptor in forum 5 Series BMW
    Last Post: 09-30-2005, 02:50 PM
  4. M60 3L rough idle , white smoke at start ,and more problems
    By Brent in NZ hartge 535i in forum 7 Series BMW
    Last Post: 04-08-2005, 11:07 PM
  5. M60 3L rough idle , white smoke at start ,and more problems
    By Brent in NZ hartge 535i in forum 5 Series BMW
    Last Post: 04-08-2005, 10:52 AM
