Results 1 to 7 of 7
Thread: Clutch Slave Cylinder
    Mar 2004
    Default Clutch Slave Cylinder
    91 525i Manual, 129K miles
    I am getting a high pitched squeak from my clutch slave when depressing the clutch, I think. Bill R suggested I take the slave off and lub the plunger where it meets the "thing" that pushes on the throw bearing; this seems like a good idea! I haven't gotten around to it! I'm technically weak and intimidated by taking this apart! It is a little awkward to get at too.
    How long does the clutch usually last, in a "carefully" driven car? I'm wondering if I'm getting to the limit of the clutch and the slave cylinder. Maybe I should just buy a clutch kit and slave from BMA and have the work done by a mechanic.
    Any thoughts please!
    Helm, Ottawa, ON.
    Canada, ON
    Helm,
    The clutch last around 200 000km.
    I am guessing that if this is the original clutch, there isn't much life left.
    The clutch kit cost 299.00 Cdn + tax
    The slave cylinder cost: 60.00 Cdn + tax
    I would change the complete shifter linkage at the same time (all the wearing parts) and install a Z8 shifter if you plan on keeping the car.
    A E28 flywheel might also be a good idea if you are into upgrades.
    Default Good advice...does an E28 flywheel work on a 525?
    Quote Originally Posted by Bruno
    .... I would change the complete shifter linkage at the same time (all the wearing parts) and install a Z8 shifter if you plan on keeping the car.
    Rebuilding the shifter linkage is a wonderful thing and very easy to do while having a clutch job done. Parts are relatively cheap. Reward yourself and do this....
    Jeff
    Bellevue WA
    86 Porsche 951 - Track Toy
    Mar 2004
    Default thank you Bruno
    I've got 129K mile or about 208 kms. so it looks like I'll have to put some money away.
    Tell me more about the E28 Fly wheel, please.
    Helm
    maybe you should take it in and have a mechanic grease the parts and see if that cures the squeek, might save a lot of money.
    Default Grease what; the pivot that the clutch release arm acts upon?
    Might as well change the clutch once you have access there. The release bearing usually wears out first on sanely driven cars, not the clutch lining.
    erased due to slander
    Default ok i follow, sounds like a bit of fun.
    Quote Originally Posted by Martin in Bellevue
  1. Changed my Slave cylinder, still a no-go
    By Monastie in forum 5 Series BMW
    Last Post: 02-21-2008, 08:21 PM
  2. Clutch slave cylinder let loose E34 M50
    By bissellh in forum 5 Series BMW
    Last Post: 05-01-2007, 06:08 AM
  3. slave cylinder
    By sanoe in forum 5 Series BMW
    Last Post: 08-22-2006, 02:07 PM
  4. help bleeding clutch slave cylinder
    By iainand in forum 5 Series BMW
    Last Post: 08-10-2005, 07:07 PM
  5. Replies: 0
    Last Post: 10-10-2004, 11:05 PM
