Results 1 to 2 of 2
Thread: Rear Caliper Piston
    Houston TX
    Default Rear Caliper Piston
    Can't get the rear piston in all the way to install new pads......have done rears several times...using good c clamp...old pad to keep piston straight...even started car and hit brakes which cause the piston to push out to ensure it wasn't frozen but when I go to push it back in...can't get that last 1/8th inch....ARGHHHHH was supposed to be an easy job.
    callen 94 530i 91 535i 89 735il
    Default try crackin the bleeder when you compress it.
    is it from a rust ring around the outer edge of the rotor?
  1. ATE Caliper piston supplier
    Last Post: 11-16-2006, 09:15 AM
  2. sticking rear caliper
    By RIPN RAY in forum 5 Series BMW
    Last Post: 07-05-2006, 10:46 PM
  3. Does anyone know the various E34 caliper piston diameters?
    By nuclearfusion in forum 5 Series BMW
    Last Post: 06-19-2006, 12:09 AM
  4. e32 4 piston caliper info and general ramblings
    Last Post: 05-15-2006, 03:48 PM
  5. Replies: 0
    Last Post: 02-23-2004, 09:45 AM
