Results 1 to 9 of 9
Thread: lost of electrical help for newbie, wont crank
    Sep 2004
    Default lost of electrical help for newbie, wont crank
    I just bought a 1990 525i 5spd for next to nothing. Doesn't crank. The interior wiring is a mess. P.O. had installed/removed aftermarket stereo and it seems to have an aftermarket alarm installed. Only recently (since I first looked at it) the cluster display center stop showing anything, the headlights stopped coming on (parking lights still ok) and the power windows stopped working
    I think the cranking issue is just a bad starter solenoid but I would like to solve the newer electrical gremlins mentioned before I get into that because I dont know if the ECU is getting powered with the cluster display center not working.
    If i cant get it right it's getting parted out.
    Henry Helfman
    Check main fuse by battery... or fusible link.
    make sure the battery is fully charged, next to nothing will work on these cars with even 11.5 volts. Battery might be toast and you might need a new battery. start at the basics and go from there
    Sep 2004
    fully charged new battery. The fusible link by the battery looks like a 10 gauge wire. Could very likely be just a wire in place, considering the workmanship of the P.O.
    So here's what doesn't work
    Starter (confirmed bad starter)
    headlights
    power windows/sunroof/mirrors
    cluster display lights up but no message can be read
    I tried jumping that fusible link with no improvement. Is there another fusible link somewhere in this car that could have fried? Does anybody have a interior wiring diagram for an e34? If I know the power window circuit, I could trace it because the fuse is showing power.
    somethings blown, no reason for the headlights not to work cause the starters bad...I still say its something stupid
    Sep 2004
    I got the headlights to kick on by smacking the fusebox. took off the cover and specifically it's that long black relay. if i tap that the headlights come on.
    You're probabaly right. judging by what people say it would seem like a fusible link, although my power seats work fine. The car didn't come with a radio so I cant tell about that but this is what bothers me. I bypassed the fusible link by running straight to the battery and the power windows/sunroof/mirror/cluster information computer still dont work. I'll still put in a new fusible link but I cant see that solving this problem.
    Does my car (battery under hood) also have a fusible link behind the back seat or anywhere else?
    I noticed that they replaced the battery ground wire was recently replaced with an aftermarket one and it only goes to the ground post under it (RH frame) should another part of the chassis be grounded?
    <I think the starter being bad is just a complete coincidence. I'll get a reman tomorrow and hopefully see this thing run for the first time>
    You can manually check the starter... First check the electric... see if you are getting 12 V at the starter... big cable... and use ground as negative... if 12v, then you are good.
    Then on the selenoid... one side is positive... jump the positive from big starter cable to that positive on selenoid... it will spark... or use remote starter... if starter cranks, then starter is good... if nothing but a clunk, then selenoid is good but starter is bad... If just whirring, selenoid is bad. If nothing happens, then use a hammer and whack the starter... try again.
    Check that ground cable... make sure it is in contact with clean bare metal... anything short of that is trouble. Check for main fuse under the rear seat... that is where all the fuses are.
    Sep 2004
    I did that before I bought the car, which is why I was confident the starter was bad. (and also why I bought it) Replaced it today, heard it crank for the first time but not fire. Sounds like a broken timing belt. If I'm not mistaken this 1990 2.5 is an M20 and interference? I got bigger problems...
    Interior electrical problems aside for now. Does this engine definately have bent valves or have people just replaced broken timing belts and been okay? If it's bad, it's getting parted/junked immediately!
    Thanks BMW guys
    Default I just had that happen to my 1990 525i and you will definitely have bent valves,
    I picked up a reconditioned head complete with brand new valves, 3 angle valve job and new cam for $700.00 from www.headsonly.com. hope this helps
    Quote Originally Posted by bigblue
    Thanks BMW guys
  1. Crank sensor problem: A note on Crank sensors
    Last Post: 01-30-2008, 07:18 PM
  2. Newcomer - Newbie Section - Newbie Owner
    By rufryder in forum 5 Series BMW
    Last Post: 09-27-2006, 01:16 AM
  3. Newbie with some newbie questions re: wheels, CD changer
    By hauler_525iT in forum 5 Series BMW
    Last Post: 10-18-2005, 10:49 PM
  4. Replies: 13
    Last Post: 08-26-2005, 11:35 PM
  5. Newbie with baffling electrical question
    By e9nine in forum 5 Series BMW
    Last Post: 05-02-2005, 12:03 PM
