Results 1 to 3 of 3
Thread: Rear window stopped working...
    Default Rear window stopped working...
    My drivers side rear window stopped working the other day. It used to stop working and I'd just give the inside of the door panel a whack, and it'd start working again. Now, I whack it and no luck. I've pulled the door panel to look at the mechanism amd nothing obvious like a loose connection or anything. Any way to check if it's the motor only... or something in the gears?
    Seems like it would be easier to replace only the motor (no rivets to remove) but obviously I don't want to do that, if that's not the problem.
    Any help?
    hold the button and slam the door a few times.
    Minnesota
    Are you sure it's not switch related? You might be able to change the switch to one from another door to see if it makes a difference. This might not be it if it has trouble both opening and closing, but might be worth a try.
  1. Heater Blower and Rear Window Defrost NOT WORKING
    By BimmerJack in forum 5 Series BMW
    Last Post: 03-25-2008, 09:07 PM
  2. Horn Stopped working...!?
    Last Post: 09-11-2007, 12:44 PM
  3. Heated rear window not working.
    By shadow400 in forum 5 Series BMW
    Last Post: 03-05-2006, 12:24 PM
  4. A/c stopped working
    By DukeNeverwinter in forum 5 Series BMW
    Last Post: 10-13-2005, 04:12 PM
  5. Bmw (525tds)'95---sunroof stopped working...
    By jesax in forum 5 Series BMW
    Last Post: 04-30-2005, 07:44 PM
