Results 1 to 9 of 9
Thread: what and where to I tap into switched power for radar detector?
    Default what and where to I tap into switched power for radar detector?
    Got the new valantine ready fo action and want to wire it properly and not like PO did by running it to the window switches.
    The valantine uses a phone cord for power so it is a long lead and I cant use the existing wiring.
    I dont really want to pull everything apart but will if I have to.
    Thanks!
    Benneton (United Colors of)
    my switched power for my changer is tapped off the purple wire on the cassette player harnes, but as you said "no jurryrigging".....
    Default anything easier? lol
    NY
    For my v1, I pulled off the sunroof motor cover, and snagged the 12v that powers the main light right in the center, with the 3 switchs on it. It worked fine, but I had to remember to turn the v1 off when I parked, because that 12v was always on. I picked it simply because it was the closest that I could see, and I wanted to mount it close to that piece.
    You may be able to use the sunroof switch... see if there's a 12v supply on one of those wires when ignition is on. I never checked it out, I was basically lazy about the whole thing.
    Custom Turbocharged 1991 535iM - 135k mi.
    Default seems the sunroof switch just triggers
    a relay to power the motor, not true voltage. Im prodding around up there and will find something, lots of room to stash wires and crap in there so thats where I'm gonna figure it out from.
    Default there is NO switched full power in there...
    wired direct for now, need to route a switched power run up into there from somewhere. Where to place this thing...I have it currently under/behind the mirror. Nowhere else is stealth if you want to get radar comming up from behind.
    Tampa Bay, Florida, USA
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    Default $hit...exactly what i needed a bit ago...
    dont remember this in there so goin back out. You KNOW i'll report back...lol
    Default No Such Wire
    grrrrrr
  1. best radar detector / gps to integrate into e34
    By gymkata in forum 5 Series BMW
    Last Post: 11-22-2006, 08:40 AM
  2. OT: Radar Detector Install to Power on
    By saj3n in forum 5 Series BMW
    Last Post: 07-19-2006, 10:33 AM
  3. radar detector..
    By xuor in forum 5 Series BMW
    Last Post: 04-18-2006, 12:39 PM
  4. What Radar Detector do you use
    By 1995 525i in forum 5 Series BMW
    Last Post: 02-07-2006, 09:50 AM
  5. Radar detector install
    By m5maniac2001 in forum 5 Series BMW
    Last Post: 04-03-2005, 09:58 PM
