Results 1 to 10 of 15
Thread: Engine noise from a 3l M60
    Melbourne (Australia)
    Default Engine noise from a 3l M60
    Hi Guys and Gals
    My '93 530i with 194,000kms has developed a worrisome noise in the engine.
    My guess is that it is timing chain related.
    There is a real racket at start up with varying degree of noise particularly from 1,500rpm upwards. The noise varies with acceleration / deceleration etc but is always noticeable when the stereo is off (Deep Purple and Judas Priest are particularly good at covering up the noise).
    Looking at the ETK there are 3 chains but my noise appears to be upper engine related so exhaust chains? or tensioner?
    Does anyone have any experience or advise on this?
    What is the most common failure in the V8 timing chains?
    What risks if I continue driving (valve timing, metal filings through the engine etc)?
    Reid (530iA)
    Kingston, Ontario, Canada
    Reidal, as an M60B40 owner, I'd have to say...I really don't know. There very nice double roller chains, just saw mine last night doing the oil change, but I'd think that if they are the culprit and they're making that kind of noise, they're not far from getting much worse. I don't honestly know if the M60 is an interference engine, i.e. a hung valve would slam the piston top and bend a con rod if a cam chain broke, but you might try opening the oil fill cap as the engine idles (safety glasses of course, and don't stick your finger in there) and look at the chains that you can see right there...the noise should be pretty obvious if it's the RHS chains.
    Cheers,
    Duey
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    m60s are known for loose oil pump bolts, it's a possiblity that air is getting into the oiling system and pissing off the tensioner
    Default Winfred is right...
    If you haven't already done so, you shoulf remove your oil pan and check the oil pump mounting bolts. M60 engines had issues with them coming loose and falling into the oil pan. My 530i had one bolt in the oil pan and the rest loose at ~80,000 miles. You'll also need to replace the oil pan gasket with the upgraded one while your in there. The new style ones are rubber/metal instead of cork.
    Noise could also be a failing water pump. Check to see if you are loosing coolant from around the bearing or weep-hole, with the engine running at normal temperature.
    Messerschmitt
    Default Thanks everyone for your advice.
    The noises are getting worse so I expect I'll clearly id the cause in the next couple of days.
    Could some one please confirm that the oil pump is accessable from below by removing the oil pan lower section only.
    Looking at the ETK, removing the upper oil pan looks like a major job.
    Regards
    Reid
    Reid (530iA)
    Default No problem...
    The oil pump is accessible by removing the lower oil pan only. No need to remove the upper pan (big job)
    Messerschmitt
    Default The news isn't good.
    Oil pump was just hanging on by the skin of it's teeth. Tightened it up and adjusted out lots of slack in the chain.
    Still noisy.
    Replaced the Timing Chain Tensioner. Still noisy.
    Removed the right rocker cover (RHD divers side). So much slack in the main chain the tensioner doesn't seem to have much effect.
    Chain is available locally at the stealer, but guides are 3 weeks from Germany.
    I'm betting the chain is a more common problem as evidenced by the fact they are available ex stock here in Aussie.
    Does thias make sense? or am I just engaging in wishful thinking?
    Does any one have horror stories of loose oil pumps wrecking engines that they can cheer me up with (NOT)?
    Regards
    Reid
    Reid (530iA)
    not personally but i've herd several, the oil pump falling off is not a good thing and in some cases that's how they found out it's a problem
    Quote Originally Posted by Reidal
    Default Plan of action.
    Hi all
    My plan of action.
    Change the oil pump and drive chain.
    Change the main timing chain and tensioner.
    Cross my fingers, toes and any other appendage I can and hope the mains and big ends have survived.
    Question 1) Is what I'm being told true, many internal parts for the M60 engines are no longer available?
    Question 2) If Q1 is yes, does anyone know of aftermarket suppliers of bearing shells, rings, chains etc.
    Gaskets and seals don't worry me so much, but the specialist hardware should be still available for that first rebuild (which is what most of these cars would be coming up to a round about now)
    I find it hard to believe that BMW could get away with not supplying basic reconditioning parts for a car which is only 10 years old.
    I'm beginning to wish I had listened to my wife 3 months ago (but I'd never admit it to her of course).
    Regards
    Reid :-(
    Reid (530iA)
    just relax, as long as synthetic was in there you have NO worries. 1st ex blew a head gasket in her truck, I drove it here to fix it 40 miles, NO water at all, exhaust was bright cherry red when I got here, fried anything that wasnt iron under the hood. Builder told me everything would be toast, I took in 1 cracked head and went on my way with gaskets, he didnt believe me so I tell him why aint I getting anything else then? Cylinder walls were still virgin and NO knocks after. Synthetic is a wonderful thing.
  1. Replies: 12
    Last Post: 02-27-2009, 11:49 AM
  2. Engine noise
    By jakewied02 in forum 5 Series BMW
    Last Post: 10-27-2007, 03:00 AM
  3. 535is engine noise..
    By Jake Casson in forum 5 Series BMW
    Last Post: 11-14-2006, 04:02 PM
  4. engine noise
    By acm525i in forum 5 Series BMW
    Last Post: 02-03-2006, 01:41 AM
  5. Noise from the Engine maybe?
    By Chrisvk in forum 3 Series BMW
    Last Post: 07-19-2004, 03:26 PM
