Results 1 to 4 of 4
Thread: Any suggestions for cracked head? Changing tomorow
    Aug 2004
    Argentina
    Default Any suggestions for cracked head? Changing tomorow
    Hey guys, do you have any suggestions because tomorow im taking the car to the mechanic to fix the cracked head (he thinks so) He thinks that its cracked because hoses are too tight and the system looses coolant(we dont know where). I have changed the head gasket and the problem keeps on.(also changed water pump thermostat, hoses, fun clutch)
    I will apreciate any suggestions because the mechanic cant solve me the problem in once. So he keeps trying with my car and makes me waste money and time. So your experience will help me very much.
    Thanks for your pecience as always.
    (I hate to be so boring with this problem that trapped me 5 months ago.)
    Pablo
    Mar 2004
    Are you sure there is no other way to find this leak without changing the head? Seems like a desperation move (I have been in that position with my transmission prog issue) but maybe there is a dye or something you can put in to allow it to show up like AC refrigerant leaks?
    07 525i 22K, 07 328xi (41K)
    Default Dosent this mechanic...
    know how to read spark plugs to tell if coolant is in the combustion chambers or test exhaust gasses if leaking into the exhaust side ? In either situation you would know if this was happening yourself. Is there water in the oil ? There is dye that you can put into the coolant but you need a black light to see it. If your having such a problem with the guy why not go to the dealer ?
    I think you need a new mechanic, with as much money as you probably have wasted it might be well worth getting a second oppinion.
  1. M50TU cracked head/headgasket?
    By bubba966 in forum 5 Series BMW
    Last Post: 03-19-2009, 05:22 PM
  2. What else should I do when fixing a cracked head?
    By landon in forum 5 Series BMW
    Last Post: 09-19-2006, 02:34 AM
  3. Blown Head gasket / Cracked head M50 Vanos
    By MotoMan in forum 5 Series BMW
    Last Post: 03-09-2005, 12:46 AM
  4. M20 Cracked Head
    By ocampg in forum 5 Series BMW
    Last Post: 10-03-2004, 06:40 PM
  5. 89 bmw - cracked head gasket
    By panthro in forum 5 Series BMW
    Last Post: 03-18-2004, 08:50 PM
