I agree with what has been said100% I do about 3-4 bimmers a month not including redoing mine evertime someone wnats the system.
my steps:
1. go to: http://www.bmwe34.net/e34main/upgrade/stereo_wiring.htm(print & keep
** I have it laminated*** then disconnect battery
2. remove the head unit 2 allen screws on each side of the radio use a sharp pointed object to open the clip there in there. (if your tool are in the case its one in there) pull it out take a large flat head screw driver and pry up the lock on the plug (there is a little scetch of it on the plug) pull out the radio.
3. use adapter plug or cut each wire seperately and connect new head unit
ower ground& anntenna or remote on off wire
4. remove rear seat top -NOTE:[U]careful with the seat belt cover on the top back of seat where it meets the rear deck: SLOWLY pull up on both sides if them with both hands so they don't break. [/U]
run rca plugs from front to rear of car ( this is a 45min job if all seats are out)
5. go inside trunk remove panel at rear & cut small hole in large rectangular rubber grommet & push the cables throught to the trunk.(Didn't know it was a full metal jacket back there huh?) remove the factory amp and cut and reuse the wires this is where the diagram from the link above is key.
6. mount amp where cd changer is ( you have to go inverted w/ selftaping metal screws. or where ever you like it. If the amp is over 500watts use a Capacitor & perferably use 2 amps small one for the mids & highs & big bass amp.
7. If you are installing subs look in the middle ehre the arm rest goes and kick out that panel so the sound will come through.
8 test the system & if its to loud turn it down till you get to the beach
email me if you hit a snag mrbmw1@hotmail.com
i'd list the stuff in my cars but it a laundry list good luck
If anyone sees a black 94 540iA w/MRBMW on a Marine Corps tag in Florida BLOW REALLY LOUD! I probably still wont hear ya
94 540i- 2.50 HP Racing exhaust, 2 3/4 lowered,18.8 HP Evo's,
88 325ic- AC Schnitzer chip,3' lowered ,M3 body kit, 17.7 TSW Ribs
Michael A. Johnson
Mighty Mike's Sound & X-cessories
MRBMW1
