Results 1 to 3 of 3
Thread: O2 sensor connector?
    freezin ass cold WI formerly freezin ass cold MN
    Default O2 sensor connector?
    Ok, I got the 02 sensor unscrewed form the exhaust. How does it come apart from the connector? Do you squeeze it? I can't get it apart. Thanks
    95 540 six speed, Rondell 58 wheels, nothin else special
    79 911 SC - pea soup green
    Kingston, Ontario, Canada
    Scott, you'll see there are two little plastic clips on the car-side harness at the connector that attach to the two low profile lugs on the sensor-side connector. I found it easiest to unclip the connector assembly from the under-floor clip and then use a flat blade screwdriver to gently lift the clips and then lever the connector halves apart.
    Cheers,
    Duey
    p.s. Wow, your sensors must not have been that bad to remove...even after a day of soaking in LPS-break free, I still had to use a closed-end 22mm wrench and a mallet to loosen mine. I had to unplug the connectors first to get the wrench along the wire to the sensor body.
    1995 540i/6 Sport Pkg w/E.A.T. chip and Nikasil injection Duey's Gallery
    Thanks. I got em. Once I got a light under there and it stopped raining (of course it started raining after the car was up) I figured it out. Yeah, they came of pretty easy with an open ended wrench and most of my body weight. I gave them a good soaking for a couple day in row. I was surprised since it's spent every winter of it's life on salt bathed roads .
  1. Does anyone know this connector?
    Last Post: 11-03-2008, 09:44 AM
  2. 02 Sensor Fail Code-sensor Didnt Fix??
    By tonyvt328is in forum 3 Series BMW
    Last Post: 05-02-2007, 10:54 PM
  3. Problem with oxygen sensor connector
    By M Malaviya in forum 5 Series BMW
    Last Post: 04-08-2007, 06:05 PM
  4. Replies: 0
    Last Post: 08-13-2006, 06:48 PM
  5. Nothing connected to the O2 sensor connector
    By phildg2000 in forum 5 Series BMW
    Last Post: 12-26-2005, 08:23 AM
